Dear All,
I would kindly ask for your help. At my conutry, there are various types of analog and mostly digital-dmr communications that i want to listen to, we have some encrypted tetra also, but as it's not possible to listen, it's trivial in this case. At the moment, i'm scanning with opengd77, but those are low budget stations with this FW (bad voice, bad rx etc.), so i would like to advance to something more. I cannont decide, which of mentioned scanners to buy. I have some questions:
- is there any additional software addons that I need to buy, if i want to listen to cap+, con+ or hytera systems on aor or uniden or it's in the basic fw? I have seen it's also possible to find gssi on tetra, even encrypted...
- can you make a scan list, that is a mix of cap+, con+, analog etc. repeaters? For example on opengd77, i put cap+ repeaters as convencional, added some analog etc. and scan it through. I need a scanner, that is capable to scan through those systems altogether. There are idk. 10-20 frequencies to be scanned
- can you listen cap+ as con+ repater? We actually have cap+ reapaters, but mostly don't work as trunked
- does those two scanners ignore RAS - motorola system?
Thank you for your help and answers
