I thought so too but I only found two on the forum search.
This will include results from other sites as well.
sds100 internal gps mod - Google Search
Both spoke of an older internal GPS mod with the Reyax 835 unit and didn't mention how it was wired in.
They all have vcc, gnd, rx and tx. I seem to remember when I did my 436 only using vcc, gnd and either rx or tx. I did not do internal and run power off a pack that holds 3 1.5 AAA. I did not want to cut up my case, but something I am considering now.
You can look up the pinout on the modules these guys used to determine if its rx or tx thats used but they used a usb cable so not really internal.
Ok, I’m more and more impressed with my new SDS100 scanner and just learned that it has GPS capability (with an added external module). Heck I was impressed that you could just type in the zip code and pull in all the local services fit to scan. And that’s all good unless you are […]
hagensieker.com
Making a GPS for the SDS-100, total cost is about $42. I searched for and read lot's of threads. This is what worked for me. Hopefully it will save you some time or money. Buy a GlobalSat BR-335-S4 $30-$35 on Amazon http://a.co/3aMYTZk Buy a pack of mini usb male type b plugs $7 on Amazon...
forums.radioreference.com
On internal, I am not sure where anyone has connected the power.
When I did my 200 I used this and the onboard antenna was weak on reception even tho others used that module with great sucess. I must have had a dud. I returned it.
Then I got this
And while it works, I am going to be getting the first one I had and will be mounting it inside the 200 since I ran across an external magnetic antenna that I had forgotten about. I will also mount a small rocker switch on the back.
