How do I program both scanners with the same Sentinel program? Thanks.
T TexScan780D Member Premium Subscriber Joined Feb 20, 2003 Messages 1,162 Aug 9, 2020 #1 How do I program both scanners with the same Sentinel program? Thanks.
fxdscon ¯\_(ツ)_/¯ Premium Subscriber Joined Jan 15, 2007 Messages 7,212 Aug 9, 2020 #2 TexScan780D said: How do I program both scanners with the same Sentinel program? Thanks. Click to expand... Create a separate "Profile" for each scanner in Sentinel, and choose the appropriate target model from the Sentinel "Tools" menu. .
T TexScan780D Member Premium Subscriber Joined Feb 20, 2003 Messages 1,162 Aug 9, 2020 #3 fxdscon said: Create a separate "Profile" for each scanner in Sentinel, and choose the appropriate target model from the Sentinel "Tools" menu. Click to expand... How do I make different profiles?
Whiskey3JMC DXpeditioner Premium Subscriber Joined Jul 16, 2006 Messages 6,872 Location 40.0417240450727, -75.23614582932653 Aug 9, 2020 #4 TexScan780D said: How do I make different profiles? Click to expand... Simply choose File > Save As to create a new profile for each scanner. Just make sure you don't accidentally write one to the other. Might be worth creating a backup of one to a separate SD card you can fall back on if needed
nessnet Member Premium Subscriber Joined Jan 22, 2007 Messages 1,769 Location Eastside of Lake WA Aug 9, 2020 #5 reminder: profiles can differ between radios, the favorite lists are common. So, set up and save 2 profiles for each Just change the target model -
