dispatchgeek
Control channel goes "brrrrr"
I've discovered an issue with my SDS100 recently regarding Full Database scanning by zip code. My SDS100 is my travel scanner, and I've previously used it without issue when going on business trips or vacation by using the zip code functionality.
I had a SD card corruption and rebuilt the card/DB from sentinel.
The last few trips after the SD card rebuild I've noticed that it will not scan the MPSCS or Starcom 21 from the full database.
1. All service types are on.
2. Range is 10 miles, in one instance I was less than 2 miles from an MPSCS site. Manually scanning this site from a favorites list worked as expected.
3. Nothing in set in avoid on the full DB.
Any ideas? I'm at a loss. I'd rather not do a factory reset, but I assume I am heading that direction.
