The leaving the control channel is very suspicious. Have you tried a new memory card just in case?Oh gotcha, I just realized that's the screen recorder for my phone.
I'll try some things for a couple days and let you guys know what I find.
I've got plenty so I'll give that a try as well. I only listen to MARCS so I can't really compare to much of anything else.The leaving the control channel is very suspicious. Have you tried a new memory card just in case?
GREAT call! Put a fresh one in, errors are at zero and the RSSI is much more stable. The noise level is even lower, and NOAA even comes in so much better in my living room...The leaving the control channel is very suspicious. Have you tried a new memory card just in case?
The SD card controls every function in the scanner. I had a friend with a BCD536HP that wouldn't even light up and appeared to be totally dead. Replacing the SD card fixed everything.So how the heck does a card make that much difference?
It's magic!So how the heck does a card make that much difference?
Maybe we can get back to the intent of this thread in regards to new firmware and any issues arising, instead of Ubbe's "my feelings are hurt because Uniden never asked me to write code for the scanners." which seems like every helpful thread goes down that rabbit hole.Ubbe maybe you should design and build your own perfect scanner. Seeing you know so much. Please do I would love to buy a perfect scanner designed by you.
They're not, @jasonhouk has the ear of Uniden and relays issues. The thread is/was about the new firmware release which I'm expecting something related to that when I receive an email of a new post on the thread and not another one of your anti-Uniden rants. As far as I know, Uniden has not released the SDS150E which would be for you in Sweden, and since you don't own one, might want to sit this one out. I'm more interested to read about those that loaded the firmware up and experiences they're having...that's what this is all about. Does it work...what happened if it didn't? This scanner is a powerhouse, and the firmware additions make improvements for those of us that own them. Let Jason handle communication with Uniden, they're listening.I've been working 35 years with everything from pagers, cellular phone control centers up to country wide digital trunked system from portables audio issues to system level problems and I have been sent to different countries around the world to solve issues. I use my experience to try and explain to others, that could have less experience, what could be wrong when something doesn't work as it should. I give my own personal opinion of what I think is going on. Uniden might be listening or they might not.
Only the frequencies, that are needed to be able to scan, are initially loaded from the SD card to RAM and only takes up a couple of kilobytes.
/Ubbe
What kind of SD card did you put in it?GREAT call! Put a fresh one in, errors are at zero and the RSSI is much more stable. The noise level is even lower, and NOAA even comes in so much better in my living room...
Sorry if it's blurry, I'll see if I still have the package when I get home.What kind of SD card did you put in it?
That's my point. Uniden needs to improve their check of data integrity if something have gone wrong with the data information that have been stored. Now it seems like users get no information that data are corrupt, the scanner just works in strange ways and you have to try and find out yourself by some random actions like reloading data or swapping SD cards and check if it made a difference.Could it have been writing to the drive when power was lost? Could it have been writing to the drive and got dropped?
Uniden really needs to improve their data integrity check in the firmware code. All frequencies that should be scanned and monitored are read from the SD card and put in RAM working memory for quick access by the CPU. When a carrier are found it reads additional data from the SD card to try and match the data that have been decoded from the transmissions.
If that additional SD card read are disturbed, difficult to read the data by some unknown reason, that somehow makes the RF reception be worse, then that are a major issue for Uniden that needs to be fixed.
/Ubbe
Yup I can see it good. I might give ordernone and give it a try. Mine acts a little wonky at times and maybe that will help.Sorry if it's blurry, I'll see if I still have the package when I get home.
