I work as a field engineer for a company’s products in Ohio and drive OH, Michigan, PA, quite often. Sometimes IN, KY, WV
(I do not do any feeds, or use the scanner to broadcast to any scanner apps or anything like that)
on one vehicle, I had a larsen triband antenna with NMO amount. On the other I just had a scanner BNC 800 Mhz antennex ducky connector.
My main priority is 700/800 Mhz systems like OH MARCs
I used to use my GRE PSR-500 for mobile monitoring but it doesnt do well anymore with simulcast
I also couldnt stand all the constant programming I had to do keep up with TG’s alphatags and changes to the system sites/freq. I simply do not have that time anymore.
I did appreciate how that scanner would still stop on an ENC TG, show the freq alphatag (and even radioID) - at which point I would manually hit lockout. Or sometimes, there was one-sided encryption where I could hear one side (but not the other)
So with that said;
Can I change these scanners so they will stop on the enc TG’d with aftermarket software like GITHUB X27/CFT?
Next up, what do I gain with spending more for the SDS150 vs SDS100?
Is one better for mobile monitoring with less programming gymnastics?
I want the scanner to ‘roam’ and go to the next site automatically as I drive thru counties and states?
Where do these scanners GPS get their database from? Something up to date like RR’s database or the manufacturers database which is updated who knows how often, if ever?
Any help is appreciated.
So with that said;
