If while scanning and I select "Avoid" then press again and it says "permanent" avoid, is this permanent avoid only valid during this scanning session and then it is no longer a permanent avoid when the scanner is turned off and back on?
Not sure if this is by design because after turning the scanner back on, the "permanent" avoid is gone.
Thanks!
Thanks!
