I've been doing some research into the hardware to do a Raspberry Pi-based remote head for the SDS200 and BCD536HP, and it looks like a finished unit in a decent case with a 7" touchscreen, ready to plug and play, would be $150-200 out the door.
I'm looking forward to following your progress with this project. I really like the concept.The remote is going to use the LAN/Wi-Fi ports on the scanners for remote control and streaming, and possibly USB (for control only) as well, so it could be used to control multiple scanners over the internet, as long as it can see the scanners' IP addresses. My goal is to support the SDS and x36 families at a minimum.
Regarding the user interface, I'm looking at going with something along the lines of Siren and the HP-1/-2 since I've got a touchscreen, but with a dedicated fourth line for site info, and applying site holds and avoids without the user having to play with a Function key. And instead of using the scroll knob to scroll off an active transmission or cycle through menu items, you swipe up and down on the touchscreen to scroll, and tap a menu item to select it. To control multiple scanners, there will be a row of icons for each connected scanner, and when you touch an icon, that scanner's information is shown in the main display area. If the user isn't using the screen, (no touch registered for 15 seconds or so), then when a transmission comes in, the active scanner's info is automatically displayed.
Considering their is a large, HUUUUGE amount of people that don't consider the sds200 to be worth more then 200....I doubt you're idea is profitable...but alas if you build it, theirs a sucker born every minute...some guy said at some point, good luck though. IMHO.
I looked on eBay and did not find the $200 sds200 I might want one
Weird. Looking on ebay ATM, and see one used SDS200. 9 bids, current top bid $586.Considering their is a large, HUUUUGE amount of people that don't consider the sds200 to be worth more then 200....I doubt you're idea is profitable...but alas if you build it, theirs a sucker born every minute...some guy said at some point, good luck though. IMHO.
