SDS200 dimensions
PJH
The manual doesn’t specially state, but until ours arrive I need actual and accurate dimentions of the 200.
I am working with a couple of console manufactures to see if we can get the radio into a certain console onfiguration, but none of us have a radio in possession to get anything going yet.
JohnnyGent
Chicago Burbs, IL
This isn't accurate? Uniden wouldn't lie would they?SDS200 True I/Q™ TrunkTracker X Base/Mobile Scanner - Uniden
Scan on.
PJH
It’s only 2 of 3 dimentions
Anderegg
Enter text in this field
San Diego
Just measured mine...it is exactly 7 inches wide, a mm or so less wide than a 996, and a mm or so less than 3 inches tall, and exactly 5 inches deep not including the buttons and BNC connector. The SDS200 is the EXACT width of a Motorola dash mount radio (Spectra, Maxtrac, XTL, APX), so the SDS will happily rest inside inside the brackets of the Motorola HLN6042 8 ohm 7.5 watt desktop speaker tray. :)
Paul
JoeyC
Senior Member
San Diego, CA
Paul
Since you mentioned it, how is the speaker on that speaker tray? Does that SDS200 have enough audio to run that speaker and sound amazing? Recommend?
Anderegg
San Diego
It's a great speaker. 8 ohms so it's not putting a strain on the audio amp in the scanner, and plenty loud and clean for in room monitoring, even with the SDS or the newer Whistler scanners with low power speaker output. You can crank them up to max with absolutely no distortion. My TRX2 and WS1098 also fit in the Moto tray perfectly. You can just cut the Moto plug off and splice or solder on a 3.5mm.
Paul
