sds200 display question
crippledchicken
Butler County MO
I have written a different FL to my scanner. Now I don't have the digital error display. Right above The RSSI is Batt and above that is Site ID. Do I need to change that somehow in Sentinel or Proscan? It was written using Proscan. Thanks!
Ace9133uwu
|-/ Nothing kills man faster than his own head.
the Hoosier state, baby.
Remember: (almost) anything you can do with software, you can do manually on the scanner itself. That said, if you want Digital Error to display, go to your: Menu > display settings > customize > (set screen), and you can adjust to your liking from there.
nessnet
Eastside of Lake WA
Remember - favorite lists are common to all profiles.
Profiles are unique. Save one for each radio you have (file/save as). Then use file/open to change between them.
I get bit by this once in a while.
I have 100s and 200s. Each have a bit different display configs and sometimes I forget to switch and get a different GPS baud rate or voltage display than the 100 or 200 is set up for.
crippledchicken
Butler County MO
I tried that but all I could come up with was simple or detailed choices. I chose detailed but everything is still the same. I'll try again if still no luck I'll check the software.
crippledchicken
Butler County MO
I looked in Sentinel and Proscan both. I couldn't find anywhere to add the digital error feature. So I decided to write a FL from Sentinel and now error counter is back. There's probably a way to change it in Proscan I just haven't found it yet. I swear, that update must have screwed up my phone too! My text is slanted now LOL!
tvengr
Well Known Member
Baltimore County, MD
The Digital Error Count can be added only in wider fields. Each field has its own listing of options available. It cannot be entered in the narrow fields at the bottom of the display.
crippledchicken
Butler County MO
Everything shows up at 0 error so I guess everything is fine. I was just wondering why it's programmed in on Sentinel but not Proscan. Thanks!
