Just received my 2nd SDS200 from Scannermaster updated the Main firmware it was 1.10.08 so I decided to update my other one and that said already updated 1.10.00 ! What gives??
Several threads on that:Just received my 2nd SDS200 from Scannermaster updated the Main firmware it was 1.10.08 so I decided to update my other one and that said already updated 1.10.00 ! What gives??
I search for it didn't see it. Thanks, TedSeveral threads on that:
Uniden SDS 200
Something strange here. I just received a new SDS 200 the firmware version is Main Version 1.10.08 Sub Version 1.02.01 The SDS 200 that I have had for awhile has firmware Main Version 1.10.00...forums.radioreference.com
BC125AT - 1.05.01 latest firmware - any updated info?
Hello All, Got an analog scanner to have fun with. See my unit when it turns on says 1.05.01. Can't find anything online but 1.03.01 Wonder what changes there are between these two versions - where can I get more current info? Is this the latest firmware? BC125AT SS (Software is: 1.03 rev...forums.radioreference.com
Nothing to worry about. New firmware is not always better. The next new firmware update might even undo changes in 1.10.08 even though it might appear to be even newer than that. IE: 1.10.08 may have fixed a very minor infrequent issue but in doing so it may have caused other problems that weren't there before.Just received my 2nd SDS200 from Scannermaster updated the Main firmware it was 1.10.08 so I decided to update my other one and that said already updated 1.10.00 ! What gives??
The way I see it the silence on Uniden's part about putting the firmware update for the SDS200 on Sentinel is not helpful It should be there period!Nothing to worry about. New firmware is not always better. The next new firmware update might even undo changes in 1.10.08 even though it might appear to be even newer than that. IE: 1.10.08 may have fixed a very minor infrequent issue but in doing so it may have caused other problems that weren't there before.
Where is "there"? How do you put firmware anywhere if it hasn't been developed yet?The way I see it the silence on Uniden's part about putting the firmware update for the SDS200 on Sentinel is not helpful It should be there period!
Apparently you didn't see my 1st post yes it exists I have on my new SDS200 and not on my older SDS200 because its not available on Sentinel.Where is "there"? How do you put firmware anywhere if it hasn't been developed yet?
What are the specific operational differences you see between the 2 scanners? Please explain what is now a feature in your newer scanner that is not available in the older one.Apparently you didn't see my 1st post yes it exists I have on my new SDS200 and not on my older SDS200 because its not available on Sentinel.
That might be a needle in the haystack. Only Uniden could definitively answer what the difference is between versions. Could simply be a bugfix or tweak, not a new feature.What are the specific operational differences you see between the 2 scanners? Please explain what is now a feature in your newer scanner that is not available in the older one.
The best explanation I can give you is what I said in post #4. I don't know for certain, just my guess. Have you contacted Uniden and asked them?Apparently you didn't see my 1st post yes it exists I have on my new SDS200 and not on my older SDS200 because its not available on Sentinel.
Not necessarily. Simply put that the version has been retracted and cross it out. That way people know what was attempted to be fixed but it didn't quite work out. I see that a lot with the products I manage.I seem to recall someone saying they had a SDS200 with the newer firmware in it from the factory but when they ran Sentinel replaced the newer firmware with the older firmware. They might do something like this if the new firmware had a bug. In that case there's no need to discuss it as it would bring everyone in-line with the good version as soon as they tried to update it. If Uniden divulged such an action they're be bombarded with phone calls and emails for months!
Exactly, what I would describe as a housekeeping change, which has zero effect, better or worse, when monitoring a system.Could be a spelling fix in the menu/sub menu or very minor tweak that wasn't even sent to test in beta.
YESI seem to recall someone saying they had a SDS200 with the newer firmware in it from the factory but when they ran Sentinel replaced the newer firmware with the older firmware. They might do something like this if the new firmware had a bug. In that case there's no need to discuss it as it would bring everyone in-line with the good version as soon as they tried to update it. If Uniden divulged such an action they're be bombarded with phone calls and emails for months!
Have you tried to update your scanner that has the newer firmware? If you try, Sentinel may replace it with the older version...which might actually be better.![]()
This is where UPMAN would of chimed in and set the record straight! I miss him! I think its time Uniden gets a replacement so we have an idea whats going on! ThankYou.Not necessarily. Simply put that the version has been retracted and cross it out. That way people know what was attempted to be fixed but it didn't quite work out. I see that a lot with the products I manage.
However, I don't think it has been retracted, as it's being placed on new scanners.
Nothing that I Know of complete silence from Uniden!What are the specific operational differences you see between the 2 scanners? Please explain what is now a feature in your newer scanner that is not available in the older one.
So more than likely, by your own observation, some very minor difference needed in newer production units that won't have any effect on your older scanner.Nothing that I Know of complete silence from Uniden!
