I bought two SDS200’s at the same time. One has developed a flickering display (I believe it’s also been described as vertical lines?). My questions are for others who have experienced this problem. Currently the flickering Is barely noticeable and I may tolerate it if it doesn’t get any worse. (The scanner is out of warrenty so I’m in no great rush to ship it off for a display replacement.)
1) Will the flickering get worse with time?
2) Does the fact both of my SDS200‘s, purchased on the same order, and were probably from the same manufacturing batch, give a positive indication that if one developed the problem the second one is probably not far behind?
