My SDS200 monitors an analog EDACS system as well as some digital systems. Lately after being on for some time, all analog transmissions will be distorted and sound "robotic" with scratchy distortion. My SDS100 has never had this issue and can receive the same signals in the same location without issue. Once this distortion starts only a power cycle will resolve. I have changed filter settings, moved the unit and swapped antenna. While this is happening all digital signals will sound fine. It is not the speaker either as audio sound distorted when passed through Proscan (ethernet) as well. This never happened until recently but now happens often with no changes to the EDACS programming or firmware. I do tend to leave the unit on quite a bit since it feeds Proscan. Should this unit go back to Uniden for repair?
