You can always use the outdoor antenna of your choice by mounting it on a floor lamp, possibly in conjunction with a broom handle with 10 ft of low loss coax..What's the best indoor antenna for the SDS200? I can't put anything outside. None of the whip antennas I've tried have worked on simulcast systems.
The poster here is using an sds-200 which has an SDR chip which overcomes simulcast distortion.Simulcast presents its own problems, where more is not necessarily better. So, poking an antenna outside of your window, while beneficial for conventional stuff, may make overcoming simulcast issues worse. There have bed. Many posts proclaiming a paper clip does better on simulcast systems than anything else they’ve tried. The floor lamp/broom handle approach is a variant of this. It gives you the ability to change where you locate your antenna without having to move your scanner. The scanner is placed where you want it annd the antenna is moved around looking for its permanent home. It could be just a matter of inches or feet. (I only use the sites best suited for my home when programming these systems. And low loss coax is always a must when working with the higher 700/800MHz frequencies, where most all simulcast issues are found to be present. It’s hit or miss with simulcast. The guy next door may be able to hear stuff you can’t, all because they’ve found that “sweet spot” a place to park their antenna. In my case, I use 50 feet of LMR400 coax to connect an outside rooftop directional antenna. It’s thick and stiff but a short piece (just enough to allow for the tight bends needed to make the final connection to the scanner) of more flexible coax is used as a jumper to connect to the scanner. They make low loss cable just as good (or maybe even better) that is thinner also. But I don’t have simulcast issues, at least not yet!
2 story house with scanner in bedroom. I have been using a suction cup antenna on the window, but now it seems a lot weaker.What kind of house and where is the scanner located? The antenna that comes with the 200 works fine on simulcast. I listen to a few.
What floor? Scanner near a window?2 story house with scanner in bedroom.
Which model? If it's not tuned for the freqs the simulcast system uses it might not be that good.I have been using a suction cup antenna on the window, but now it seems a lot weaker.
I am aware it a SDS200… I’ve got two of them. The paper clip was just one example, driving towards the intended method of moving the antenna, trying differing antennas, etc., granted, these ideas were offered to those who were t using an SDR receiver. But mostly to point out it the location of the antenna that’s important. An outside antenna isn’t necessarily the answer. And while I am not bothered by simulcast issues (as my BCD325P2 works just fine), the software defined radio microprocessor chip you refer to isn’t infallible. The SDS200 may still have the need for tweaking the location and type of antenna used. Thanks for pointing out the various “tweaks” that were offered for those having trouble with simulcast when using the BCD436 and 536’s. That point completely slipped my mind.The poster here is using an sds-200 which has an SDR chip which overcomes simulcast distortion.
The paper clip method that you talk about was one of the many gimmicks, like drilling a hole in a empty paint can and putting the rubber duck in it to overcome simulcast issues and is certainly not the same as a good quality rooftop antenna mounted on a floor lamp or tripod.
Yeah my County went Phase ll simulcast in 2015, rendering the x36 useless just a year or so after getting them. We had to go over to apx radios to pick up my counties system.I am aware it a SDS200… I’ve got two of them. The paper clip was just one example, driving towards the intended method of moving the antenna, trying differing antennas, etc., granted, these ideas were offered to those who were t using an SDR receiver. But mostly to point out it the location of the antenna that’s important. An outside antenna isn’t necessarily the answer. And while I am not bothered by simulcast issues (as my BCD325P2 works just fine), the software defined radio microprocessor chip you refer to isn’t infallible. The SDS200 may still have the need for tweaking the location and type of antenna used. Thanks for pointing out the various “tweaks” that were offered for those having trouble with simulcast when using the BCD436 and 536’s. That point completely slipped my mind.
I know you said you can't stick anything outside, but a cheap and dirty idea is IF you don't have Double pane windows, then a Glass mount mobile scanner antenna would work much better. I think Scannermaster.com still markets some.What's the best indoor antenna for the SDS200? I can't put anything outside. None of the whip antennas I've tried have worked on simulcast systems.
I think that's a good antenna, but the original poster could also try the BNC 7-800 model that was once the RS 800 and just get a right angle adapter.Would this possibility help? I have the handheld version of this antenna and it works really well.
REMTRONIX 800 MHz FLEX BNC Antenna | Scanner Master
REMTRONIX 800 MHz FLEX BNC Antennawww.scannermaster.com
