My area (greater Hartford CT) is very busy for UHF business licenses and it is common to have several DMR users on a frequency. Confirmed color code could help prevent false hits if you have similar congestion.
chris
chris
When you press Function plus the System key to resume scanning, you'll get a prompt yes or no, do you want to save what it's found.I have the sds200 using LCN finder on a DMR System so far it has found 2/5 but it does not saying anything on the screen to save. it just has to scan above the system key?????
Are you running the LCN Finder and confirming the LCNs?I just installed a roof antenna and I now see many confirmed LCN and a few unconfirmed LCN with strong frequency signals, but I hear no one. Can someone show me how this LCN is used or set up on my SDS200 ?
What system?, What LCN in the "this LCN" that you are referring to? Did you do a search, found some channels and are trying to make sense of them?I just installed a roof antenna and I now see many confirmed LCN and a few unconfirmed LCN with strong frequency signals, but I hear no one. Can someone show me how this LCN is used or set up on my SDS200 ?
I use ProScan on both my BCD526 and SDS200. I do see +CON on my screen. What is this finder you mention. Is it based on a full data base scan?Are you running the LCN Finder and confirming the LCNs?
Once you have run the Finder, and it has found LCNs for one of your systems of interest, use Sentinel (or ProScan or ARC536) to read the data from the scanner back into the software, and save that data. Remember that if you run the LCN Finder again on a system, it resets all the system LCNs back to zero (unknown LCN) before starting the find process again. For the LCN Finder to complete it's task, the system needs to be busy enough that most if not all of the channels are used. If there is not enough radio traffic, you won't see the LCNs for the lesser used frequencies be identified. On the other hand, if the system is extremely busy, that can complicate the LCN process as well, leaving you with incomplete information.
For the scanner to correctly track an LTR, DMR,, or NXDN system, you need to have the LCNs entered for each system. For a system where you have found all of the active channels, you can scan it with the correct LCNs in place.
If you are seeing other frequencies, with a strong signal, that appear to be from another system, you can program them as conventional frequencies, then if you are using a program such as ProScan, you can log the activity, looking for one or more 'sets' of frequencies using the same Color Code (DMR) or RAN (NXDN), which can perhaps point you to a new system that was not previously known. You can use the frequency search feature on your county's database page to see who is licensed for a given frequency, then look at that specific license to see if there are more than one frequency, which might be part of the system. Depending on your area, there may be more than one licensee for a specific frequency. Herein my area, DFW, many of the Uhf frequencies that businesses use have four or more companies licensed for it in my county. So a given frequency, potentially, could be used in more than one system. That's the case in my area.
On your SDS200, if you have a number of "unknown usage" frequencies being scanned, the scanner display (also the log if you are using that) will indicate a system type. "CAP" and CON" shown on the screen would indicate a DMR trunked system. If you only see DMR, then that frequency is not part of a multi-frequency trunked system.
Don't forget that the Digital Frequency Search website can give you a list of licensees for DMR and NXDN in a specific county. Just because they are licensed to use DMR or NXDN does not guarantee that they are using that mode, but it may help you identify some of your unknown items.
Absolutely. But in a dense metro area, where the same frequencies might be licensed to multiple users in the same county. And, even though the licensee has a number of frequencies authorized for a specific location, there is no certainty that all will be part of the system.LNC FINDER Trick number 1 make sure you have all the correct frequencies and the system has to be active for it to work.
The LCN Finder is one of the options under the Analyze selection on the scanner's menu. It is used for frequencies that you have programmed on an existing system, or for what you suspect is a new system. The full database does not enter into this process at all.I use ProScan on both my BCD526 and SDS200. I do see +CON on my screen. What is this finder you mention. Is it based on a full data base scan?
