The support will improve in the coming weeks.
In the mean time I will see if the issue can be duplicated.
To clarify, while using the waterfall the audio is low but when you hold on a frequency the level increases?
Correct.
For reference, my SDS200 is at Main F/W version 1.23.07, and Sub version 1.03.05
I have the DMR, NXDN, and Waterfall keys installed, if that matters.
I select the Air Band under Start Preset Waterfall and manually tune to an active frequency for a nearby airport (126.975). Squelch is at 0. Gain is Auto. Mode is AM since this is the air band.
I set the Span such that I can hear audio while it is sweeping (less than 5.76MHz). I need to turn the volume up to 17+ to even hear anything when a transmission comes in. If I tune to another frequency while Sweep is active, the volume stays low.
If I change the Gain to manual and increase it to the max of 15, the volume increases a little but not as much as when I hit Hold.
If I hit the Hold button, the volume jumps up to the level it would be during a normal scan.
The volume problem only seems to be for AM modulation. If I edit the waterfall to have NFM, the volume does not decrease but stays at the expected higher level.
Is this normal behavior?
I've also observed that if I increase the span to 5.76MHz or greater and keep Sweep active, I hear no audio when a transmission comes in, regardless of the volume level or squelch setting.
I'm not sure why the span matters during a waterfall display. Sweep should be allowed and signals should be heard if they come in on the frequency being displayed regardless of the span value.
