Agreeing with /Ubbe.
I had occasion where I too had a mobile two-way radio, a BCD536HP (replaced with the SDS200) and a roof mounted light bar installation, much like the Chief’s car at the center of the OP’s question. The light bar and radio were wired directly to the battery, both leads were fused and the proper guaged wire was used. However, the scanner was different. I have chosen a power connection at the fuse box inside the passenger compartment that is powered by the ignition switch, my sole intention was/is to have my radios (I also have a ham transceiver) shut off with the vehicle’s ignition switch. When the vehicle is turned off everything goes off including the SDS200… without a chance to write any changes to the SD Card. I have never used the “Replay” or “Record” features. I have never needed to replace the SD Card (but do have two spares, one for the vehicle and one for the house, I have 2 SDS200’s) which I will update from time to time. If I ever do have a problem, I’ve got my backup SD Cards. When I make a change to the SDS200 in my vehicle I simply remember to first use the recommended method for turning the scanner off. After it has written to the SD Card and shuts down, I then turn it back on. Now that my changes have been saved I’m good to go.
The OP need only to do three things…
1) Turn off replay/record
2) Instruct the chief when making changes such as “Avoiding” or “Unavoiding”, to turn off the scanner using the recommended method AFTER the changes have been made. Wait for the scanner to finish writing to the SD Card, which saves your changes. And THEN turn the radio back on. It takes only seconds to write to the card.
3) And, just in case the Chief is interested as to WHY his scanner was acting the way it was, you can explain it to him. (But it’s been my experience Chief Officers are more interested in things that work and discard that which doesn’t… in which case, tell him you shut off the replay/record features as it is the only way the scanner will shut off with the ignition. I believe powering the scanner in this manner (using the ignition) is probably the best method in the fire service for a few reasons. One is fire apparatus usually use a battery switch that divorces all battery power with the exception of mobile charging cradles for the portable radios and meters, etc. with lesser power requirements. The battery switch is pretty much engrained into the fire service so it’s used in the volunteer firefighter’s personal vehicle. Because no one wants to come back from a fire to a dead battery in your personal vehicle, all due to a failure to shut off a warning light or radio.
