I cannot get the priority scan to work on my SDS200. I am using ARC536BASIC, Version 2.2, Build 10 - Full Version. I have the priority channels set and I have confirmed it in the in the programming. However, once I start scanning, I get the message: " Priority Scan, No Channel". I even went through the scanner and confirmed it manually with each channel and the priority is set. I also tried simply priority scan and still the same. Anyone have any suggestions? Is this a programming software issue or a scanner issue? The scanner firmware is up to date. Any help would be great!
