Sds200 problem
Coburnsun
Ky
Why will my sds200 not pickup any of these frequencies? I know the first is encrypted but I don’t understand why not the others. Thanks in advance
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The first listing says P25E in the mode. This is encrypted; no scanner can decode it. The Law Tac and Fire Tac freqs are likely low power; you'd need to be close to the scene to hear these. The water freq is not likely to be very busy on weekends, and maybe only occasionally during business hours l
Mike
Coburnsun
Ky
Are the appropriate service types enabled?
I’ve got them saved on auto
Mike
Exactly & I stated that I understand that, however the others should be receiving correct? I live about a mile from twn
They’re on auto far as I can tell, I’ve had to setup manually since the program don’t work on apple computers
KevinC
The big K
Super Moderator
1 point
Press Menu, then scroll to Service Types and enable the appropriate ones.
Coburnsun
Ky
I done that, still haven’t had anything on that frequency come in. Wonder if the location on the setting has anything to do with it?
I would guess that most of the traffic on PD 1 D has moved to the encrypted PD 1, as for the T/A and Fire ground, you'll need to be in the immediate vicinity, like 1/2 a mile or less because they are usually low powered simplex. Multi-Dispatch may mean that is a paging channel, not voice. The water channels may be meter readers and not voice. But, as others have mentioned, setting the scanner to auto does not turn on the Service Types.
ofd8001
Louisville, KY
Just for diagnostic purposes, program whatever National Weather Service frequency is used in your area. Assign it a Service Type that is active in your Profile.
If the scanner stops on the weather channel, you can Avoid it. If not, then there is a bigger programming issue.
Coburnsun
Ky
I’m picking that up as well as several p25 departments that’s a lot farther out than the PD. Scanners doing good just can’t fine tune that one department when I think I should be able to do so
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
What "one department"? As several others have mentioned, your police are fully encrypted (mode P25E) so they cannot be monitored by any scanner. It wouldn't make much sense to me for Prestonburg to encrypt their dispatch channel yet leave others analog conventional so it's quite possible they discontinued use of them although the database still reflects the old analog info
ofd8001
Louisville, KY
Are you sure Prestonsburg PD uses those channels often enough to hear? There is a lot of joint dispatch operations and they may be using Floyd County channels. (Considering all possibilities).
I agree with setting the audio option to Search which casts a wider net on chance the database may be out of date.
