Car95
Have a new sds200 it was prog done by scanner master have Essex County in it can pik up newark nj fire has data and single help
Understood but you can still check service types as I suggested on your own. Fire Dispatch & Fire Tac need to be turned on for you to hear fire talkgroups. Better to learn how to make adjustments on your own than to rely on themThanks but scanner master did the programming
Sorry John, I didn't see your post until after I did mine.Make sure all applicable service types are turned on for the talkgroups you want to hear (reference "tag" column in database) otherwise the scanner will omit them. Vendors often do a shoddy job programming systems for others so you'll want to learn how to do the job yourself in the event something goes wrong or if the system undergoes changes you'll be ready. Uniden Sentinel makes programming easy
Make sure they are all on.Just check fire dispatch and fire tac are on
LOL no worries it happensSorry John, I didn't see your post until after I did mine.
Not sure what you mean by "actuator", what are you trying to turn on or off? The service types?Sorry to bother but does the SDS200 have a actuator you can turn on or off
Attuater
