bramahbull2
- Joined
- Nov 25, 2017
- Messages
- 4
I have searched for the easiest way to remove the recordings on my SDS200and and so far my own method seems to be the fastest and easiest so I will post it here.
1.Power off your scanner and remove the micro SD card.
2.Insert the SD card into your computer. I use a MAC but a windows computer will work also.
3. Double click on NO NAME or whatever SD icon represents your SD to show the files and folders on the SD card.
4. Double click folder BCDx36HP.
5. Double click the folder named Audio.
6.Double click on folder named user_rec.
All the files and folders within this folder are all the saved recordings.
7. Perform a select all and insure you only have the files and folders within the user_rec folder highlighted then delete or remove to trash to delete all recordings on the SD card.
8. Close all folders and Safely eject the SD card from your computer and reinsert it into your scanner.
9. Power on your scanner and after it boots up press the function knob then press the replay/record button on the keypad and follow the on screen instructions to start your recordings by pressing the E/Yes button on the keypad to initiate recording.
