slylingus
- Joined
- Sep 25, 2009
- Messages
- 74
Just recently I have noticed the SDS200 rebooting with a strong signal.
Has anyone else noticed this happening or is it a built in safety?
I use an external antenna tuned to my network around the 166mhz (NO Preamp)
The main system I monitor is The Regional Mobile Radio Network that is a VHF P25 trunk network.
Filter setting off as this tower is only a couple of KM away the signal strength is around 50db.
Volume set to 23 Squelch set to 3
The scanner is rebooting with Strong UHF signal also.
I have not changed data cards as yet I will do that in a couple of days.
I have added a YouTube clip. scanner reboots at 1.14 there are a couple of other scanners receiving in the background.
can I log these errors somehow ?
Thanks in advance just a novice here so not technical info.
