GlobalNorth
I've had my SDS200 for years now and it's been reliable. Recently, the screen has started to noticeably flicker. The scanner is usually on all the time and only gets shut down infrequently.
The only 'solution' I have found is to turn it off for various periods of time and then turned on again. It might work for a week or just for less than a day. The screen settings are on color, detailed info, and using the factory color settings.
Is this a known fault that will need addressing or just a quirk that can be ignored?
