SDS scanners has demodulation noise, the more the signal are modulated the more noise you get. A digital signal are fully modulated so you can probably not get any lower values than the ones you see now. If you listen to just a silent analog carrier you will get 0 as a noise value at about that -80dBm level. As soon as someone starts to speak on an analog channel the noise will go up in a SDS scanner.
If you do not receive any signal at all it will be all noise and the highest value are in the 50,000 range.
You can use the Noise value for analog signals and when you try different filter settings and IFX, to get the lowest possible noise value.
Fot digital signals you will need to configure one field to show D-Error and will show how many errors in the data signal that you have, and try to get it as low as possible using filters and IFX. If that goes higher than 10 then you will have a bad signal with bad audio, or none at all, being decoded.
/Ubbe
