None of the 7 SDS200 units (3 are mine, 4 setup for others) I have dealt with show any signs of popping, hissing, humming, or other extraneous audio artifacts.
Please see post #33.
But haven't people that have had the hum say it doesn't appear on recordings or in ProScan? Maybe the same with the popping?
Hum or popping can appear if using the copper connection. An isolation transformer will fix that.
Maybe tomorrow. I'd have to shut down all the other scanners I've got running to get clear audio.The pop does not occur over network audio. Can you please just post a video of your scanner following the guidelines I set forth previously?
Sounds about right. Now I want to see who DOESN'T have that issue and what's different about their units.Here is a video of my sds200 taken with an iPhone about 6 inches from the front with the internal speaker. There are various volume levels, etc. Some shots showing the popping when going from 0->1 on the volume. I was controlling the volume from proscan.
->link<- to my thread about this showing details.
Jon, what do you know about the audio output circuitry in the SDS200? Usually, a pop or thump is caused by DC voltage applied to the speaker. Is there a possibility of a shorted output capacitor or a DC imbalance in the output of the amp if it is direct coupled. I would check to see if there is any measurable DC voltage across the speaker. If so, the level should change when the pop occurs.I've seen plenty of people indicate they hear the noise in headphone audio, and I've heard the noise in YouTube videos recording scanner audio straight from the scanner, so I don't think that's the case. My SDS200 doesn't have any hum, CPU RFI, or popping, so I can't test to confirm or refute that either way. What you hear in the recordings I posted is the same as what came out of the speaker, minus the room background noise.
If there is a capacitor inline with the output (and there usually is, specifically to block DC voltages), you won't see a DC voltage across the speaker. But when the amp powers on and off, that can change a DC voltage on the input side of a capacitor and cause a thump or pop as the capacitor charges or discharges. I don't have access to a schematic, so I couldn't tell you specifically what is happening.Jon, what do you know about the audio output circuitry in the SDS200? Usually, a pop or thump is caused by DC voltage applied to the speaker. Is there a possibility of a shorted output capacitor or a DC imbalance in the output of the amp if it is direct coupled. I would check to see if there is any measurable DC voltage across the speaker. If so, the level should change when the pop occurs.
Been listening to my SDS200 until I return it after the New Year. I noticed the humming seems to be getting louder and within the hum I hear what sounds like random static. Would be happy to do the Static Discharge fix but I don't know that it would fix the popping noise from the internal speaker. No sense in messing with it and getting the return denied due to mucking something up. I can hear the popping noise from 6 feet away and it isn't dependent on volume. It is always the same level.
Although I know you can set volume offsets for channels, and I believe talk groups, I wish you could set them for individual radio IDs. I am listening to DMR at a comfortable volume, and can hear some people who are speaking quietly, but there are some people who sound like they got their microphone in their mouth and are yelling. Wish there was some sort of audio limiting.
The "static" is RFI from the CPU leaking into the audio circuitry because of improper grounding. The StaticDischarge fix solves that problem. My -200 has the StaticDischarge fix, and doesn't have any RFI noise or popping in the internal speaker.Been listening to my SDS200 until I return it after the New Year. I noticed the humming seems to be getting louder and within the hum I hear what sounds like random static. Would be happy to do the Static Discharge fix but I don't know that it would fix the popping noise from the internal speaker.
An update.
I got a replacement SDS200 and it does NOT have the popping sound at the beginning and end of transmissions. I got it from a different vendor and the serial number is 300 less than the one that had the popping sound.
Both had Main version 1.06.25 and Sub version 1.01.10 when I got them but I updated both to the latest version.Does it have the latest firmware? If not, what version is it?
