Is there a way to have an alpha tag if you know the Unit ID#? Can you have an alert or volume offset for a particular UID?
Yes,yes, yes/no: you can set an alert per Unit ID/Radio ID. This is easier to do on a Phase 1 P25 system since the Phase 2 UID Capture issue is still problematic. Cap+ and NXDN Trunking systems it can be done too.
I have compiled many active radio ID lists, and if you're main focus is on a fire department, even easier. Most apparatus radios remain the same, and officers/engineers/firefighters radio identification is similar to the apparatus.
On police departments, if in-car use, this can be easily documented. Some officers are assigned portables, and utilize the same radio signatures, so also easy to do.
As mentioned, time consuming and tedious, but keep a pen and paper near by (as I do), and get ready to write.
***One thing I forgot to mention. In order to see your identified radio ID's, you have to Edit the Display in a field to show Unit with Name. This can be done on either the Simple Trunk or Detailed Trunk tab.***
