29a
I am curious if there is anyone who might be able to post any info on how to listen to the Uniden SDS200 scanner audio using VLC Client? My scanner is on my LAN with a Static IP, and the connection is correct and setup properly. I use the Uniden Software on my iPhone to access the SDS200 audio on my LAN, it works, but I'd like to use VLC because it is vastly available on many devices, would allow me to enjoy more scanner audio on more of my devices if only I could get the settings correct and everything configured properly. I've seen on YouTube that people are having success listening to their SDS200 scanner audio using the LAN Connection & VLC Software, but when I go to look for spacific settings that are needed to monitor the audio stream I seem to be unable to find any correct info that really talks about the LAN features and settings for the SDS200, such as Ports and what and what not the SDS200 can do via the front LAN Port on the scanner. Any "technical spacifics" would be appreciated.
-29A
-29A
