SDTrunk ---> <_ _> SYNC LOSS - BTS PROCESSED (9600)
AB9NN
Beulah, MI
When I look at Messages for the currently playing tuner tuned to the correct frequency I get the following message over and over:
It is a very strong signal and decodes nicely in DSD+ FastLane. What am I doing wrong?
DRL-XM43
Durham Region
Is this a P25 system - are you trunk following - what version of SDRTrunk are you using?
If it is P25 is it a Phase 1 or 2 system?
AB9NN
Beulah, MI
This is a P25 Phase I system. How do I determine the version of SDTrunk I am using? I think it's 6 months to a year or so old. I have it installed in the following folder:
C:\_Files\SDR - Software Defined Radio\sdr-trunk-windows-x64-Alpha-09
DRL-XM43
Durham Region
It may be best to udgrade to the latest versions then go from there
DRL-XM43
Durham Region
So what system is it? What decoder is selected?
(Easiest to link to the RR DB page to see the system)
Some/Any information will help folks to help you.
AB9NN
Beulah, MI
System is here: https://www.radioreference.com/apps/db/?sid=100 - search for "Beulah" and find control channel at 853.9625 which my tuners are tuned to. It is Michigan's Public Safety Communications System (MPSCS) which is Project 25 Phase I. I specified Decoder Type = P25 Phase I and Modulation as Normal (C4FM).
AB9NN
Beulah, MI
I am able to tune the same control channel/system and decode/follow with DSD+ FastLane quite nicely. Therefore it's probably not a tuner issue.
DRL-XM43
Durham Region
As you have done before, you should log the issue with the SDRTrunk support forum I am sure it would be resolved quickly, we know it is not the software so it has to be something other.
DRL-XM43
Durham Region
Update for others experiencing similar issue.
Make sure you have not applied a message filter.....
(issue solved).
AB9NN
Beulah, MI
filter was not applied. Issue not solved... I have cross-posted in the SDRTrunk help forum.
rspears1966
AB9NN, I had the same issue, my solution was to ditch DSRTrunk and move to FMP24 and DSD+ Fastlane (I only use one SDR radio).
If you're running everything on one PC, here's the command lines (or .bat file code):
1) FMP24 -rc i1 -o20001 -P0.0 -a1 -b-12.5 -f853.8500
note: -f will be the control freq of your local P25 system
2) DSDPlus -r1 -e -T -E -i20001
note: this will create a .wav file in the local directory and it will become extremely large over time
note: this will pipe audio out to your default windows device, make sure you set this before you kick off this command
That's it. Two command lines, and one SDR radio. Decoded P25 traffic.
Hope this helps.
Bobby
AE4B
DRL-XM43
Durham Region
Hope this helps.
Bobby
AE4B
He said earlier that he is decoding it nicely with FMP24/DSD+ already.
