SE Michigan Skywarn
philkoz
Anchor Bay, SE Michigan
Hello all....I'm updating our area Skywarn info & websites for local counties are scarce. Below are listings from the DB. I'm looking to confirm all are correct. THANKS !!!!
MACOMB COUNTY
147.20000/147.80000 100.0 PL Skywarn - Primary
147.18000/147.78000 Skywarn - Alternate
146.58000 100.0 PL R.A.C.E.S. - Simplex
446.57500 107.2 PL R.A.C.E.S. - Simplex
OAKLAND COUNTY
146.90000/146.30000 100.0 PL A.R.E.S. - Skywarn Primary
146.84000/146.24000 100.0 PL A.R.E.S. - Skywarn Secondary
146.64000/146.04000 100.0 PL A.R.E.S. - Skywarn Backup
147.51000 100.0 PL A.R.E.S. - Simplex Ops
444.32500/449.32500 107.2 PL A.R.E.S. - Alternate
146.58000 Southfield - RACES Simplex
442.15000/447.15000 107.2 PL M.I.C.O.N. - Intercounty
443.87500/448.87500 107.2 PL M.I.C.O.N. - Future Use
ST. CLAIR COUNTY
147.32000/147.92000 131.8 PL Skywarn - Primary
146.58000 Skywarn - Fallback Simplex
WAYNE COUNTY
145.33000/144.73000 100.0 PL A.R.E.S. - Skywarn Primary
146.76000/146.16000 100.0 PL A.R.E.S. - Detroit City
147.16000/147.76000 100.0 PL A.R.E.S. - Skywarn Secondary
147.16000 100.0 PL A.R.E.S./R.A.C.E.S. - Fallback Simplex
224.58000/222.98000 100.0 PL A.R.E.S. - Skywarn (linked to 2 meters)
442.80000/447.80000 107.2 PL A.R.E.S. - Skywarn (linked to 2 meters)
LAPEER COUNTY
146.62000/146.02000 100.0 PL A.R.E.S. - Skywarn
442.75000/447.75000 107.2 PL A.R.E.S. - Skywarn Alternate
MONROE COUNTY
146.72000/146.12000 100.0 PL A.R.E.S. - Skywarn Primary
145.31000/144.71000 100.0 PL A.R.E.S. - Skywarn Alternate
442.82500/447.82500 107.2 PL A.R.E.S.
KB8UYC
Ypsilanti Michigan
MACOMB COUNTY
OAKLAND COUNTY
ST. CLAIR COUNTY
WAYNE COUNTY
LAPEER COUNTY
MONROE COUNTY
WASHTENAW COUNTY
145.150/144.550 100.0 PL A.R.E.S./ -Skywarn Primary
146.920/146.320 100.0 PL R.A.C.E.S/ -Skywarn Backup
146.580/146.580 100.0 PL A.R.E.S./R.A.C.E.S -Simplex
mikey60
Oakland County Michigan
OAKLAND COUNTY
Looks good except for the MICON listings. MICON uses the CMEN network when activated. Information on that group of repeaters can be found at http://www.n8obu.com
The 442.1500 repeater is supposed to be operational, although I haven't tried it in awhile. I've never heard a repeater on 443.875.
Mike
tusker305
Hamilton, Ontario
Mikey60, Thanks for the info, what is the PL for that repeater and Freq and Pl for the secondary repeater?
I will update and post right away.
If anybody finds outdated info on the map please let me know. A SKYWARN MAP is no good without proper info. And I want this to be a reliable referance for everyones shack. Thank You All
mikey60
Primary frequency is 146.900-/100
Secondary is 146.84-/100
Mike
iMONITOR
Silent Key
S.E. Michigan
Here is a map I made for myself. But I am willing to share.
I'm being advised from a reliable source the following:
Oakland doesn't use 145.25
MICON is not correct
PL for Livingston is wrong
I wasn't given the correct info. Perhaps someone will chime in.
detroit780
Silent Key
Michigan
Skywarn
First off AWESOME map. There are however several changes in frequencies that I am aware of that aren't reflected in the map. Perhaps someone from each county can verify the current list and then you can update it.
146.68 Livingston County uses a PL of 162.2 not 100
145.41 PL of 162.2 is backup
444.525 PL of 100 is another back-up
144.32 simplex back-up
145.52 simplex back-up
442.35 PL of 100 is now the new MICON
146.90 PL of 100 is the new Oakland County frequency
Les
Updated MICON Map.
tusker305
Hamilton, Ontario
Please Don't copy or use the above posted maps. I am just not sure how acurate the info is any more. I was moved by the number of requests I recieved for this work. So I am completely redesigning the map, with up to date and acurate information from the source. I will make the finished work available to anyone who wants it. With any luck on the RR Database if I can figure out how to do that. If I recieve the data in time I will have the complete work ready this weekend. Thanks for all the kind words and help.
RayAir
MICON has been using 442.350mhz the last few times, not sure if it is a permanent switch.
MACOMB COUNTY
OAKLAND COUNTY
ST. CLAIR COUNTY
WAYNE COUNTY
LAPEER COUNTY
MONROE COUNTY
mikey60
MICON actually has a number of frequencies throughout SE michigan. 442.35 is part of the CMEN network of repeaters that provide wide area coverage to lower Michigan. You can see more information about the CMEN network and the repeaters that make up the network at http://www.n8obu.com
Mike
RayAir
Mike
OK, thanks for the info! I was listening to 442.150 during the severe storms on June 8 and heard nothing so I did a quick freq. search and I heard them on 442.350. I always heard them on 442.150 last year. Thanks. I enjoy listening to MICON because you can hear multi-county reports and get about a 30 second+ advance warning on tornado warnings for your county,etc.
