SE Ontario P25 P1 150.710 location?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Good thinking! Here's mine for the SEARS system:
Network: BEE00.5DE ; Canadian Army
Bandplan #6: Base=136. Offset=-0.9 Spacing=10 BW=12.5
Bandplan #7: Base=136.005 Offset=+0.9 Spacing=10 BW=12.5
Bandplan #8: Base=380.0125 Offset=+5 Spacing=25 BW=12.5
Bandplan #9: Base=380. Offset=+5 Spacing=25 BW=12.5
Bandplan #11: Base=380. Offset=+10 Spacing=25 BW=12.5
Site: 1.1 NAC=5D1 ; CFB Borden
Channel 7-783: 143.835 VOICE
Channel 6-1230: 148.3 VOICE
Channel 6-1296: 148.96 VOICE
Channel 7-1363: 149.635 CC
Channel 7-1424: 150.245 SCC VOICE
Channel 6-1471: 150.71 SCC
Site: 1.2 NAC=5D2 ; Meaford LFCATC
Channel 6-1215: 148.15 CC
Channel 6-1233: 148.33 VOICE DATA
Channel 7-1261: 148.615 SCC VOICE
Channel 6-1314: 149.14 VOICE DATA
Site: 1.3 NAC=5D3 ; Petawawa
Channel 7-531: 141.315 VOICE
Channel 6-776: 143.76 CC
Channel 6-1603: 152.03 SCC
Channel 6-1690: 152.9 VOICE
Channel 7-1811: 154.115 VOICE
Site: 1.5 NAC=5D5
Channel 7-510: 141.105 SCC
Channel 6-551: 141.51 CC
Channel 7-597: 141.975 SCC VOICE
Channel 6-2999: 165.99 SCC VOICE
IdleMonitor
The Ottawa Valley - Eastern Ontario
tayridge
ELGIN ONTARIO CANADA / tayridge34@gmail.com
Thank you all for your patience and info- The following is a copy from my DSDPlus.p25 data file:-
Network: BEE00.5DE ; CANADIAN FORCES EMERGENCY RADIO SYSTEM / SEARS
Site: 1.13 NAC=5D3
Channel 7-423: 140.235 SCC VOICE
Channel 7-1348: 149.485 SCC VOICE
Channel 6-1371: 149.71 SCC VOICE
Channel 6-1471: 150.71 CC
This system is starting to "drive me round the bend" but I determined to get at it eventually. Thanks again
Dave
mikewazowski
Staff member
Forums Manager
Oot and Aboot
That's perfect.
It is part of the SEARS system. WACN:BEE00, SYSID: 5DE, RFSS: 1, Site 13, NAC 5D3.
Even throwing out the same bandplans as the two bases near me. I've updated the database and will remove the CFB Kingston entry.
tayridge
Great Thank you so much for your help as well thank you to all who assisted. Seems to be working good now and even have some new TG info. TG 11251 Range Master/Live Fire, TG 11231 Base Security/Commissionaires
TG 11247 Base Maintenance (Pumping out Manholes X 3 days and installing new wiring). UNIDENTIFIED TG's 11220, 11237, 11237, 11239, 11240, 11242, 11243, 11245, 11250, 11259.
As the TG's are identified will submit to DB. Thanks to everyone again for help and patience
Dave
mikewazowski
Staff member
Forums Manager
Oot and Aboot
One thing I've noticed is that they seem to use a common template for the groups.
11250 - 11260 will probably be Range Control. I'd guess 11250 would be Range Control Common.
You'll probably find Base MP's around 11210 and if they've got a fire department, 11220.
Each department usually has an Operations channel and then a Common channel where other departments can contact them.
