poppafred
I have ordered some of the sticky back tape for sealing coax connections against the weather but have been wondering:
Has anyone ever tried using Penetrox on the center pin and on the outer threads to stop corrosion?
I bought an 8oz bottle of the stuff to use on a new vertical and had tons left over. If I were careful to not get it across the insulator surface and kept it on only the metal surfaces, do you think it might help maintain good contact at the connector?
I've always just slapped everything together and gone on because I figured I could always go back and repair it but I am getting to the point in life that it isn't always going to be possible to correct mistakes. Figured I would do it right the first time and not have to fix it later.
