racingfan360
- Joined
- Dec 19, 2005
- Messages
- 1,190
I've owned lots of Unidens over the years.....one of the features I love is the Search and Store function. But I'm relatively new to the 436, and it seems to be missing the ability to do Search and Store????
AFAIK, there doesn't appear to be the same functionality in the 436. I'm familiar with the Discovery function in the 436, but the issue is that it's limited to searching through one single band (you define just one upper and one lower freq limit). This makes it pretty useless when you want to search for new channels across several tightly defined frequency bands. You end up having to define such a wide range for Discovery to work it significantly reduces probably of intercept. With Search and Store, you could set multiple custom search bands very easily.
The only other way I could kinda replicate this is enabling the recording function and then running several custom searches (the custom searches would do the 'searching' bit and recording would 'store' the new channels). I could cope with that, but the issue I've found is that there doesn't appear to be a way of nudging the scanner on up the band when it hits upon an active carrier. It'll just hit on the first carrier and then stay there. I can't see any hold time or time out setting to play with?
Anyone got any bright ideas? What have I missed?
TIA
Jim
TIA
Jim
