If you are using the RadioReference database, AKA National Database, you can't search and you can only scan what is preprogrammed.
But if you are talking about searching on a Favorites List that you created or imported, then all you need to do is press the function key on the side of the radio and then the E, or Enter, key while you are scanning on that Favorites List. You will see on the display that will read ID Searching instead of ID Scanning when you do that and then if you want to switch back to ID Scanning you just repeat the same steps again. Just make sure that the radio is scanning when you do the steps otherwise it won't switch between scanning and searching.
Brian
COMMSCAN
Sent from my SAMSUNG-SM-G930A using Tapatalk
