Search with Scan
captclint
Mountaintop, PA
Unlike older scanners, where you could either do search ranges or scan, the new models let you do both.
Reading this thread, http://www.radioreference.com/forums/showpost.php?p=964171&postcount=4 , I would like some user comments:
I was not aware the newer models could do this. Sounds like a nice feature.I do not see that in any of the GRE models, which makes me wonder why not. Since they came out after this feature was implemented, I wonder if there are problems. Is it too distracting to have traffic other than the search band? UPman's answer suggests you can use a custom search as well as service searches. Is that the case? I assume it is sequential (search complete limits and then scan all enabled frequencies), and not interrupted every X seconds.
JoeyC
Senior Member
San Diego, CA
You didn't look hard enough. With the PSR500/600 and the RS twins you most certainly can program search ranges and mix those ranges with freqs and/or talkgroups that are scanned.
UPMan
In Memoriam
Arlington, TX
With the Uniden models, yes it is sequential. You can define how long you want the scanner to "dwell" on each search (since going through a complete sweep could take many seconds). When it hits the search again it picks up where it left off the last time.
