OldRabbit
- Joined
- Jul 15, 2020
- Messages
- 62
I attempting to search for active frequencies using my new SDS200 using a custom search - in this case from 440 - 470 Mhz.
A custom search with these limits - and a delay time of 1 sec (which I do not understand) will search the frequency range - but the scanner stops on an active frequency and remains there as long as there is a carrier.
How do you make the scanner proceed after noting the frequency and possibly parameters of the signal ?
My goal is to gather a list of active frequencies for later analysis.
Update: Funny how I often find the answer right after asking - Found this in the 'Easier to Read SDS100/200 Digital Scanner Manual":
"Set Delay Time Determines how long the scanner waits after a transmission ends before resuming Quick Search and Close Call Search operations. A negative delay will force a resume after that number of seconds. The default setting is 2 seconds."
Regards
Regards
