Searching for Talkgroups
erickson2319
When it comes to scanning I am very familiar with analog scanners. But I just recently purchased the Radioshack Pro 197. So I'm still very new to digital trunking, and I expect to have quite a few questions in future post.
Anyway first things first, how do I search for Talkgroups to program in to my 197?
captclint
Mountaintop, PA
Welcome to RR. First you have to identify and program the system of frequencies in a particular trunking system (and correctly program the type of trunking system).. So it would help if you identified the system(s) of interest, including your state and county so we can help you. You also need to better understand trunking. This should help:
Trunked Radio Systems - The RadioReference Wiki
erickson2319
Thanks for the reply Clint. I live in Minnesota, and am trying to moniter the talkgroup system from Lake County. And actually I have already programmed the system in my radio. Is there anything else I need to do so I can listening?
DickH
Analog and digital are programmed exactly the same. Digital is just another type of modulation, like AM and FM.
If your confusion is about trunking, yes it is very different than regular scanning. Here's a simple explanation of how Motorola trunking (the most common) works.
Motorola Trunking:
The object of trunking is to allow many users to share a relatively few frequencies.
A trunking system is controlled by a computer. Information (data) is exchanged between the system radios and the computer on a control channel, sometimes called a data channel. It sounds like a strong buzz.
A large system can have up to 28 freqs., 4 of which may be used as control channels. The control channel may be changed once a day or as often as the programmer decides. Some scanners need only the control channels to track an entire system. Just put in the 4 Control Channels.
Each group of users (Fire, Police, etc.) is assigned TALK GROUPS. In a Motorola Type II system, the most common type, TGs are usually in 32 number steps starting with 16 and going up to 65536; 16, 48, 80 --- 4656, 4688, 4720 --- 28944, 28976, etc. System radios can have more than 100 TGs programmed into them.
How it works
When a user pushes the talk button on his radio, data is sent to the computer. The computer chooses an unused freq. and sends that data to all the radios that are set to the TG of the originating unit. This all happens in a fraction of a second and it happens EVERY TIME a radio is used.
EXAMPLE:
Fire Dispatch calling Engine 4 (TG 4528 on 856.7125)
Engine 4 answering Dispatch (TG 4528 on 852.2625)
Respond to 73 Elm Street (TG 4528 on 855.9625)
Engine 4 responding (TG 4528 on 851.6375)
If you have entered TG 4528 into your scanner, it will read the control channel data and change your scanner freqs. to follow the conversation on TG 4528. .
gr8rcall
Alamance County, NC
Welcome to RR!!!
As mentioned above programming analog and digital TGs is the same procedure...so you shouldn't have any problems!
Gr8rcall
AC2OY
Belleville,New Jersey
Wow Dick that was a amazing explanation!! Just goes to show on this site I can never read enough!! Very well done sir!!!
DickH
Gotta agree with ya' on that one!!!
That was awesome! Gr8rcall
Thanks guys. The explanation on Wiki is way too technical and complicated for most people, especially newcomers.
gr8rcall
Alamance County, NC
Perhaps you REALLY should put that on the wiki under "Easier to read Trunking Basic Introduction"
Noticed you've used it twice now.
Gr8rcall
AC2OY
I agree he's good real good!!! Dick do you dabble into HAM radio?!! I need a lot of help lol but I am getting better maybe by November I'll have my radio programmed...lol
DickH
Perhaps you REALLY should put that on the wiki ...
I don't like the way Wiki allows anyone to change anything that is on it. If someone wants to copy my explanation and put it on Wiki, I don't care.
