Lew
With the latest firmware upgrade I see you can seach RR using zip codes. would some one explain exactly how you do that? Do you do it with EZ scan or on the scanner or have I completely missed the boat?
Lew in SC
Lew in SC
I use EZScan, and I wouldn't call it "searching" but rather "importing".With the latest firmware upgrade I see you can seach RR using zip codes. would some one explain exactly how you do that? Do you do it with EZ scan or on the scanner or have I completely missed the boat?
Lew in SC
Hi tk,........................Only works on ZIP CODES not postal codes...Bandplan needs to be set to USA ...............................................
Also, that means my answer to Lew was a bit narrow minded, Hmnnn, don't like that, should have done better.Hi tk,
I'm a little naive about some things. I see your from Toronto. Are postal codes what Canada calls the mail areas? Are you saying that Canadians can't use this import feature? If so, that's not nice of Uniden. Maybe they are working on a second location "library".
Rob
