Security channels
Bill5489
Hello does anyone know of any security dispatch channels for the Kansas City metro area ?
hkrharry
Member - RR DB AdminMo/Ks
In the middle of the USA
That is a tricky question.
Most security companies that use LMR are DMR.
You will find them on the big three trunked DMR systems here in the metro area.
Commenco, KC Wireless, & MidWest Mobile Radio.
Some also use conventional (tier II) DMR, some also use PTToC (Zello) or similar app over cellular.
Unfortunately, you will have to do a lot of searching in DMR search mode.
Unless it has been posted in the Database or the Wiki - good luck, some of them even use encryption.
I hope this helps.
HH
wbloss
Human
Joplin Mo
A talkgroup does not have frequencies. In the system referenced above the MotoNet CP each repeater/site is linked so that a talkgroup will appear on ANY repeater. If you have a newer scanner, just download the system above using the sites near where you wish to listen, and download the TGS.
