Security channels
Bill5489
Hello does anyone know of any security dispatch channels for the Kansas City metro area ?
hkrharry
Member - RR DB AdminMo/Ks
In the middle of the USA
That is a tricky question.
Most security companies that use LMR are DMR.
You will find them on the big three trunked DMR systems here in the metro area.
Commenco, KC Wireless, & MidWest Mobile Radio.
Some also use conventional (tier II) DMR, some also use PTToC (Zello) or similar app over cellular.
Unfortunately, you will have to do a lot of searching in DMR search mode.
Unless it has been posted in the Database or the Wiki - good luck, some of them even use encryption.
I hope this helps.
HH
wbloss
Human
Joplin MO
A talkgroup does not have frequencies. In the system referenced above the MotoNet CP each repeater/site is linked so that a talkgroup will appear on ANY repeater. If you have a newer scanner, just download the system above using the sites near where you wish to listen, and download the TGS.
Bill5489
Has anyone herd any radio chatter form this talk group 6105901 ?
wbloss
Human
Joplin MO
Yes: "RP" (reporting party) "Bates City Lot", "subject" - so definitely some sort of security or LE agency.
RIDs observed on ...5901
5100115
5102311
5105902
5105905
5105906
5105914
5105916
5105919
5105921
5105911
5105912
5105909
5105930
5105929
Some of these RIDs have also shown up on 6100001 which is the BIG/main security channel, and also TGs 6100003 and 6102301, which makes me believe these TGs all belong to same organization. 003 is an early "2nd channel" 2301 a newer add, and 5901 was added later. Maybe supervisors or a specific geographic area or serving a specific assignment for the same security organization.
The RIDs of most TGs follow a similar numbering plan - eg TG 6102301 has RIDs 5102301,2,3,etc. Same with TG 6105901 RIDs are as per above. Just sometimes these "other TG RIDs" show up on the main TG 0001 and the others occasionally.
Kinda messy but I hope I make sense.
w
