Sedwick county kansas
NYPDAUX
Wichita, KS
can anyone tell me why after installing my county frequencies for trunk system but not working hear not a thing on my scaner help
Redneck0410
Hutchinson, KS
What kind of scanner are you trying to program?. Also, check this thread: http://forums.radioreference.com/ka...-cant-get-sedgwick-county-scanner-10-1-a.html There is a link by me on the final post in that thread that will point you to the Sedgwick County RR page. There are updated frequencies there that you should confirm are correct.
Redneck0410
Hutchinson, KS
Uniden Bearcat BC346XT Police Scanner
Okay, make sure the freqencies in this link Wichita / Sedgwick County Trunking System, Wichita, Kansas - Scanner Frequencies match what you have in your scanner. If you use any software to program that scanner, it will make it a lot easier, but programming it by hand is okay as well. Make sure the trunking mode is set as a Motorola system. Enter the frequencies in the link indicated above, program talkgroups as needed (depending on what you want to listen to) and sit back and enjoy. I personally use FreeScan to program my scanner. Please indicate your wishes via private message and I will be more than glad to help you out. I used to live in that area, so I know how tricky programming that system can be. If, by chance, you do use FreeScan to program your scanner already, let me know and I can e-mail you the file you need, as I have it saved on my computer.
-Shawn
NYPDAUX
Wichita, KS
Okay I've noticed lately in Wichita Kansas when I try and use my scanner some days it works and some days it does not work this p are they switching systems is radio reference going to be able to put the updated list so my radio will work all the time does anybody know what really is happening
NYPDAUX
Wichita, KS
Okay I've noticed lately in Wichita Kansas when I try and use my scanner some days it works and some days it does not work this are they switching systems is radio reference going to be able to put the updated list so my radio will work all the time does anybody know what really is happening
Using a uniden tracker three scanner and have downloaded the data from radio reference and installed
With scanner Pro
Redneck0410
Hutchinson, KS
With scanner Pro
Like I indicated in my previous post, I have FreeScan for my scanner, and I have the file you would need. I haven't heard of using Scanner Pro to program a scanner.
Redneck0410
Hutchinson, KS
I grabbed this file from ProScan, try this and see if it works for you. Open it in ProScan and upload it to your scanner in place of what you have. I have changed no settings, this is just how it imported directly from the RR Database.
Hope this helps!
-Shawn
