NCIC105
I see someone is broadcasting the same LEO feeds I've had up over a year.
Anderson County Sheriff, Fire and EMS Live Scanner Audio Feed
What are trying to say? Its not an exact duplicate of your feed so its allowed.
It's not a waste of bandwidth at all since, based on the feed descriptions, they're far from being duplicate feeds. It appears that your feed contains more than just Anderson County Public Safety communications, people that only want to hear Anderson County communications would select the new feed while people that want to listen to Anderson County and other area channels would select yours.Ok
I'll add EMS and Fire to mine...Delete one channel so it is not 100% dup.
What a waste of bandwidth!
I've found that you can duplicate a feed, add a few channels and your feed will be approved.
It might not be a waste of bandwidth but it's definitely a waste of resources on the feed providers end.
Why provide the feed if someone can duplicate what you already provide while adding little more? Your setup could be doing something else.
It would be better if the new feed only added new channels to augment what the current feed is providing.
Ok
For a provider, it does seem wrong when you are the first provider in the community to offer up a feed. While I understand what you are saying about it being a little different. It makes one wonder why go to the effort when someone else can comes in and run the same area and hawks your listeners. It appears wrong in my book. I have more ethics than to do someone like that..But some don't.
Apparently you missed the point...
They just recently started broadcasting the same frequencies and tags I am....
bnoland
