Seeing Frequencies and Trunking Tables after Import
TopFlite
MD/ Washington DC
Using Software From StarrSoft, PSREdit, and Butel and trying to Update after Rebanding new and older Uniden 996's, Pro-96 and Pro-2096, GRE 500 and 600 in our Workplace... Where on any or all of these (and Yes, I Know each is different) after Import from the RR Data Base: How do we see the Trunking Table imported or confirm the new CC's and alternates. Here in DC-VA-MD the REBANDING Storm has arrived and we do have a lot of radios. Copy and Paste is easy on Win 96 but life has become more Complicated.
puzzleriddle
bham, Bama
in psredit 500 click the trunking objects tab then th edit tab .. is this what ya need? also rebanding tab at the bottom
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Why in the world are you doing copy/paste? With your premium subscription, you should be able to use the web download to copy the necessary freqs - and the software should set up the trunking tables for you, assuming the rebanded flag is set. Once you have one radio working properly, you might be able to clone out the rest, depending on the model(s) involved.
We have a great many articles in the wiki that has to do with the software settings for rebanding - and keep in mind that with the older scanners (such as the BCD396T or 996T), you must have upgraded firmware installed before rebanding can be supported. Section 7 of the rebanding wiki talks about this, along with numerous software related articles that have to do with rebanding...
Rebanding - The RadioReference Wiki
best regards..Mike
