Hey ya'll just wanted some advice regarding my antenna setup. Everything works quite nice im just looking to make things even better. Here is a little doodle that shows my antenna situation.
So I have my airspy hf+ discovery inside and the feed line comes in under the window and is connected to the sdr. The RG-6 feedline runs underground across the backyard (~100ft or so) then comes up a small tree. The feed point isn't that high off the ground, maybe like 12-16 feet snaked up the small tree.
The coax is split open and the shield and center are connected to separate antenna legs.
The leg connected to the shield runs up to a branch on a larger tree. Past that point, it lays flat across several branches. It zig zags slightly but is mostly under the center fed leg.
The center fed antenna leg slopes upwards at a roughly 45 degree angle and rests on a tree limb far up in the air.
This antenna is for shortwave receiving only and the frequency bands that im interested in are from 80m to 20m. Anyways, the coax shield leg was my first antenna attempt and is just a wire of random length (with it originally connected to coax center with the shield grounded). After my first attempt i wanted to try a multi band end fed antenna so thats what the roughly 66ft antenna leg was originally there for (trying to cut for 40m). I did a initial test run of it but found no difference in performance compared to just having the one random wire. Also, from what iv read it seems that, for a multiband end fed, the individual wires need to be of a specific distance from each other other wise it just acts like a larger random wire.
After some searching around i settled on the OCF dipole setup. It seems like it didn't improve signal strength but it did reduce noise which makes me happy.
So anyways again, just looking for ideas on how to improve the setup some more. Would a RF choke clean up the noise? what about one of those balun/unun things, would that make any difference? Am i right about the multi band end feds, that each wire needs to be of specific distance from each other?
