AlmostHandy
Hello everyone.
I had a cheap scanner when I was a kid, and it was a blast. I recently acquired a Radio Shack Pro-97, and wouldn't you know it, it's still a blast.
So, I've read through the "Easier To Read Pro-97 Manual" over at Marksscanners.com, and I've read the "Programming Cheat Sheet" for the Pro-97 from this fine site, and I'm not sure I understand the process very well. I also have some questions regarding certain functions and their pertinence.
The list of frequencies and talkgroups I'm using is from http://www.scannerstuff.com/nwfd_WA_King.htm.
The page lists 3 simulcast cells, with several dozen frequencies each. Under that is a long list consisting of talkgroup IDs, each corresponding to one of the three simulcast cells.
As I understand it, I should program the each of the three simulcast cells into it's own bank, and program the talkgroups afterwards into the appropriate corresponding bank. Is that right?
That page at scannerstuff.com says "If your scanner is capable of Control Channel Only Mode (see your manual), only control channels need to be entered for each cell. The other (voice) frequencies will be tuned automatically by your scanner using data provided on the control channel." My scanner appears to have Control Channel Only mode, but neither of the manuals I've read talk about how it works. Can I put all 7 control channels in one bank, and add all talkgroups to the same bank or do the simulcast cells need be in separate banks?
Thank you for helping a beginner. I've been reading websites for several days, and it's come to a point where everything I read confuses me a little bit more.
