seeking file in freq order for DTRS
nathancarlson
Longmont, CO
Does anybody have a file with the Colorado DTRS frequencies in order by Frequency rather than site numbers? This may make it a little easier on me to identify the CCs I am hearing that I imported into my pro 106 since I did not think to write them down as I selected and imported them into my scan lists. thanks!
abqscan
DataBase Administrator
Moderator
AOA
Why dont you just write yourself a little sticky note with the CC's you do have programed into your radio???
jeffreyinberthoud
Banned
BERTHOUD COLORADO
does the pro 106 allow "systems" Like uniden ? just name each one by the tower location
For eample I have sunset gunbarrel & mead for boulder county I have horsetooth bald and prospect for Larimer so on
nathancarlson
Longmont, CO
I have all 20 "scan lists" or banks used up and use the VSCAN folders when I go to other areas (like Wyoming or DIA or Blackhawk) outside my normal area and this is where I get confused. All my systems like Larimer County have the system freq. programed but I can not give them each a text representation like I can the talk groups or with my old scanner. So when it stops on an object it shows me "CC 07" and I am keeping track of what CCs are being used by the agencies I monitor, and which ones I can actually pick up along my commute so I don't overload the scanner. I currently have 16 control channels for Larimer County, and I am sure that Loveland does not use all of them, so I was just trying to condence stuff a little and back off on the ammount of CCs I have programmed that are not being used. I guess it doesn't realy matter which ones they are since I am logging and if i don't get hits on certain CCs I am going to delete them anyway. I just wanted to have an easy reference to look up what I am deleting. Since the countys are listed along with the site names, it has been much easier to import, so I usually just grab all the Primary CCs for a county, see which are being used, and the ones I don't ever get hits on I just delete. Some have been surprising to me though.
jimmnn
Colorado
Let me say it once again less is better when it comes to CC programming and Loveland area would need 3 or 4 at most, certainly not 16.
Additionally I have an excel spreadsheet with all CC's and TG's listed in order if that helps just PM me an email address?
For example;
T010B 851.4125 Mines Peak (Berthoud Pass) 111
T011C 851.8875 Toonerville (Bent & Baca Counties) 128
T0254 851.9875 New Castle Cemetery (Garfield County) 284
T0253 852.0375 Rifle Communications Center (Garfield County) 283
T023A 852.0625 Sheeps Knob (Montrose County) 258
T0129 852.0625 Springfield (Baca County) 141
T0214 852.1250 Monarch Pass (Chaffee & Gunnison Counties) 220
T0312 852.3250 Reiradon Hill (Logan County) 318
T0203 852.3250 Buffalo Pass (Routt & Jackson Counties) 203
T023D 852.3500 Monte Vista (Rio Grande County) 261
T0249 852.3625 Farwell Mtn (Routt County) 273
T0233 852.3875 Delta (Delta County) 251
T0228 852.4375 San Luis (Costilla County) 240
T0245 852.4750 Poncha Springs (Chaffee County) 269
T021C 852.4750 Coal Bank Pass (San Juan County) 228
T0144 852.4750 La Junta (Downtown) 168
etc etc
Jim<
