Seeking help for 2 issues I’m having.
dimaxxxl
Waltham
New Unication owner here so bear with me as I am still very much learning. I am having 2 issues right no that I can’t figure out.
1. One of my P25C frequencies was sounding off a loud beeping alert intermittently at the beginning of some transmission. After shutting everything off i believe shutting off emergency tone silenced it. However now even with emergency tone off, I get a beep at the start of a transmission and a delay before I hear any audio. This causes me to lose the first part of the transmissions and makes back and fourth conversations impossible to listen to.
2. On most channels If I hit the reset button on the left side of the pager, it mutes the audio while holding it. Sometimes i have found it mutes the audio permanently on a channel with no way to restore it and the only way to hear traffic is to hold the reset button during a transmission. I have one channel that no matter what I try is now alway muted.
Webodisk
Silent key.
Virginia Beach,VA
Tab D4 find the talkgroup and set the alert tone to none, on tab D4 check and see if alert mode is set to none, also check on Tab d5 and see if alert mode is set to silent on that knob position
dimaxxxl
Waltham
All of that has been done. I believe it has something to do with emergency alert since when I shut that off it went from a loud beeping tone to just a quick beep.
dimaxxxl
Waltham
Not sure if this is helpful but it only happens when I get a transmission where the screen shows
To: All
Fm: 1
1 is the PD control. When Operations or any other unit keys up, it doesn’t happen.
N6ML
It appears that some systems do dispatches as "system calls", which is a type of P25 message intended to target all users on a system (I believe that's what "To: All" indicates). It seems that the G-series firmware considers these to be emergency messages, and alerts accordingly.
dimaxxxl
Waltham
There is no way to shut this off? I have emergency messages shut off and its better. I as getting long beeps and now im just getting a single beep but still miss a lot of the transmission.
N6ML
I don't know of any way to turn it off. Do you have Voice Buffering enabled for the knob position(s) ?
dimaxxxl
Waltham
I had it enabled. Should I try and disable? One interesting note. I changed the mode from monitor to radio compatibility mode and on that knob position and it seems to have solved the problem. However, in a scan list that channel is now deaf.
dimaxxxl
Waltham
So fun fact, if I put a channel in radio compatibility mode, it removed it from all scan lists and doesn’t give you the option to add it back.
