Seeking power charge cable for C. Crane (original) CC Witness MP3 Recorder-Player.
CCwitness2
I bought the original CC Witness MP3 Recorder-Player/AM/FM Radio at a yard sale. But the charge cable was missing. I emailed Crane and they no longer carry this.
Is there another compatible cable? It looks almost like an old Iphone/Ipod port. Or maybe an old, old cell phone. Is there a workaround. I'm confidant using a solder iron and opening personal electronics cases.
Right after starting to sell this model Crane came out with the + (plus model) which seems to be the same except it charges via mini-USB cable. Good move.
AB4BF
EM93cs
First search, I found this:
Hope that helps...
ETA, Looks like both original and the + model come up on the search. hmmm.
a417
U+0000
If this is true, then you can do what I've done in the past.
You open the case, you unsolder the connector that is present, you find a suitable male/female connector for your needs, and you solder the new one on.
I have done this with oddball devices, and I usually end up soldering on a barrel connctor on 4 inches of wire, so that I can use any one of the 10k power supplies that I have in my possession.
RandyKuff
Lorain, Ohio
belvdr
Yada Yada
RandyKuff
Lorain, Ohio
Yes it is for the plus model... I see the plus model uses a Mini USB port and not that proprietary one...
So that won't work...
Witness +
AB4BF
EM93cs
One more time...
Is it something like this?
