"Segmentation Fault" Error with DSD 1.4.1 Ubunto
fdnybuff18
NY
Getting a Segmentation Fault error after the program monitoring a channel with TRBO Data/Signal for about 5 minutes? Program then stops running. I noticed this only on TRBO Channels that are running constant data.
Any thoughts?
n4yek
Cosby, Tennessee
If you come up or get a solution, please post it. I asked this same question a few months ago with no solution.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I _think_ that when I ran it using a few switches, it didn't happen -- but if I ran it without any switches it did happen. I'll test again today and let you guys know what specific switches I am using when it does _not_ crash.
Mike
mtindor
FMP24 PRO USER
Mike
I was wrong. Switches or no switches, it still bails. It only does that on control channels spewing constant info. I never have it crap out on a voice transmission. Just long term constant CC info.
Mike
troffasky
You will probably need to run it with a debugger and post the output here when it segfaults, unless you can work out exactly what input is causing it to segfault.
mtindor
FMP24 PRO USER
You can set up a batch file to restart it by creating a batch file in your dsd working directory:
* dmr.bat is the name of the batch file I run
* my working directory is c;\dsd -f yours is something else change cd\dsd
* the switches are specific to TRBO (with -xr because I need to switch invertedness on my particular audio card)
* I renamed my dsd.exe [from woodpecker, with filter] to dsd_filter.exe
Code:
echo off
set /a i=0
:loop
if %i%==1000 GOTO END
echo This is iteration %i%
cd\dsd
dsd_filter -ff -mg -xr -i /dev/dsp -o /dev/dsp
set /a i=%i%+1
GOTO loop
:end
echo That's It!
- this will restart it 1000 times (modify 1000 to set number of times you want it to restart)
- doesn't matter what you echo - you don't even need echo
- after all, you'll never see what's echoed during restarts most of the time
Mike
slicerwizard
Toronto, Ontario
The error is fairly obvious; the DSD authors allocate a 1,000,000 element array and point dibit_buf at its first entry; they then use the pointer dibit_buf_p to walk through the array, storing dibit values as they're generated by getDibit() or getFrameSync(); this is done so that they can step backwards to the start of a DMR frame when they find a DMR sync pattern (which is always located in the middle of a DMR frame)
Under most circumstances, frame decoding (of any supported protocol) stops when a channel drops (RF carrier goes away) and this leads to the noCarrier() function being called, where dibit_buf_p is reset to point back near the start of the array.
When monitoring DMR channels that don't go away (e.g. control channels), dibit_buf_p eventually walks off the end of the 1,000,000 allocated storage elements and starts clobbering whatever lays in its path. Before long, you get a segfault.
fdnybuff18
NY
Code:
echo off
set /a i=0
:loop
cd\dsd
set /a i=%i%+1
GOTO loop
:end
echo That's It!
Mike
Mike,
This worked awesome.....
Thank you
mtindor
FMP24 PRO USER
Mike,
Thank you
You're welcome. I'm glad it was of use to someone else :) In case anyone wondered, I just stole an example windows batch file loop that I found on the internet and modified things so that it restart my DSD.
Mike
krokus
Southeastern Michigan
They are using an array, instead of a bi-directional linklist?
