select system to stay on bcd396xt
semperfi1110
i just used the program to program my scanner now it is still cycling through all the systems that it had pre stored on the scanner. is there a button i can push to just select one system and stay in that one. or is it always going to cycle through them all. please help.
sjlamb
Sarasota County, FL
While receiving a transmission on the system that you want to isolate; press and hold down the "HOLD" button until "HOLD" starts flashing on the display. You will then only be scanning that one system.
To resume normal scanning of all enabled systems, repeat the process of holding down the "HOLD" button to release the hold on that one system.
In the alternative, you can also enable or disable systems so that you can scan just those systems that you want to monitor at the moment. This allows you to then scan any combination of systems as you choose. You do this by assigning a System Quick Key to each programmed system and then pressing the corresponding keypad number to turn that numbered system "on" or "off". For systems numbered 11 and above, you will need to press the ".no" button followed by the assigned system number. For example, pressing ".no" and then buttons "2" and "3" would enable or disable the system assigned System Quick Key "23".
Assigning System Quick Keys is best done with your programming software as this will give you a global visual image of how your systems, sites and groups are being number as you go along. Also, you will want to consider the fact that the same Quick Key can be assigned to multiple Systems, Sites and Groups.
Understanding and becoming proficient at assigning Quick Keys is fundamental to organizing and getting the most out of the scanner's Dynamically Allocated Memory. Incredible programming flexability once you fully grasp the basics.
DaveIN
Founders Curmudgen
West Michigan
If your using FreeSCAN, you can set the systems to be locked out or not even load the preloaded systems if you want. Just be sure to select the quick key status when sending to the radio.
semperfi1110
ok i got all that done now i switched to the radio and the air and news and now it cycles them also. i am so lost. how do i get it to stop cycling through them or to just leave it on my preset systems and then be able to switch to the radio i choose to with out using the computer program. and no i dont have the free thing i was very quick to jump on the programming thing and bought the arc xt and the thing off radio reference.
