Selected Wrong Scanner When Purchased software
Twitchy1
Madison, Wis
Hello
I just purchased a reqistration key. But i made a stupid mistake I selected PRO-162 and ment to select Pro-163. Is there any wat i can fix this or should i just contact support. Thanks for any help on this.
I hope this is fixable.
Steven
WayneH
Forums Veteran
Super Moderator
Your master site
System-wide Administration is definitely not the forum where you'll find help for this. I'd recommend contacting whichever software maker it is you tried to register with. RadioReference doesn't sell scanner programming software.
In the mean time I'll move this to the scanner programming software forum....
Twitchy1
Madison, Wis
thanks for the quick response.I upgraded from the Demo software i downloaded here. But i see that the software company is different so i will try to contact them. Thanks
Twitchy1
Madison, Wis
thanks for the info. Sorry about that i thought that it was done through here since i purchased it on Radio Reference I found out what the software company was and contacted them to see if i could get different registration keys or if they will work for any scanners software program
